06 international 4300 dt466e air fan clutch removal help
SirCampbulance
Naples Fl
Hello guys I'm new here and looking for help. I have an air leak from a fitting behind the fan clutch pulley. How do I get to it. Cant find the bolts that hold on the pull . Any info would be awesome thanks
SirCampbulance
Naples Fl
Is it the air hose leaking?
Do you have a picture?
Air is coming from the fitting behind the pulley. If I push the hose in I can get it to almost stop
If you could get in there to the fitting with a flat screwdriver, you should be able to pop the hose loose. It should be a quick connect. Usually cutting the end off and reinstalling works.
Otherwise you may have to pull the fan, then may be able to get to the pulley bolts.
SirCampbulance
Naples Fl
Just tried that still same thing. Will try to take the fan off next week.
olsen726
