clutch problem
Brad kirk
Lake Ariel / United States
In the F-350 described in my sig, when i start the truck up, sometimes it won't go into first or reverse unless you shut the engine off. Also the clutch has to be pulled back up with your foot every time you use it(probably just a bad spring, how hard is it to get to that?). Any suggestions are heavily appreciated. I don't want the clutch to go out and leave me sitting on the side of the road.
Could be low on fluid..... but the bushing on the master cylinder push rod is the usual culprit.....
u2slow
bilge rat
Coastal BC
Bushing... haha
by the time i got to mine... the steel pushrod hole was egg-shaped and the companion stud was half gone!
scsmith42
New Hill, NC
As others have recommended, crawl up under your dash and inspect the pushrod to the clutch master cylinder where it attaches to the linkage from the pedal. When they wear out the problem that you describe occurs. Also problematic can be the firewall cracking and allowing the master cylinder to move.
Bronco graveyard sells a repair kit for the clutch pushrod.
If you install the clutch rod repair end, be sure not to cut your old rod too short!
Also the bushings that are installed in the clutch pedal linkage can wear and result in this problem.
tke395
