085 better spooling, zf5, and intercooled
03wr250f
Hamilton/Montana
according to justin at r&d
the ww2 picks up about 2 psi boost, faster spool up, and 10 ft lbs increase in torque on the dyno. so a pretty decent upgrade imo
oh and you cant forget the best part, better whistle!!!
david85
Campbell River, B.C.
Oh, my truck has plenty of power it scoots pretty good. A lot better egts after up pipe seal.
But my towing experience is always 20k+ gross and I’m in Idaho so everywhere I go so terrible mountains every way but south
My 460 zf5 doesn’t help with those terrible 2-3 and 3-4 gaps
What set up do you have?
My signature is up to date so all the specs are in there (3" exhaust/093/E4OD/3.55). Although, I did discover a small exhaust manifold leak a few months ago. It has much better midrange after swapping from the 088 setup to the 093. Exhaust manifold leak and the 3" tailpipe are probably not helping.
Austin86250
idaho
My apologies I don’t get to see signatures on my phone
Austin86250
idaho
There’s some room for a good air filter spot. Justin finished the intake today and my last boot shipped aswell today
Austin86250
idaho
Ready to fire when I get my body put back together, just need to put my down pipe back and make the pipes, really excited hope this wicked wheel does better than the stock one and can keep my egts manageable
Very impressed with the aluminum return caps so far let’s hope I didn’t ruin an oil ring and they leak but the fitment is insanely great
Happy to rid with the rear cross over the the 6.9 injection pump hard return line
Austin86250
idaho
Very happy with this here’s the final look need to finish the intake just mocked up and a few odds and ends but very very pleased
Austin86250
idaho
I’m going to call this project an extreme success, more power much smoother too, quieter in the cab, no more white smoke, wayyyy better egts.
There is this 7% grade before I had to take it at 50 and still be at 1200 degrees but I just took it at 63 mph at 800!
The results are impressive. I wonder if the same thing would work for a 088? I have a future project in mind.
Austin86250
idaho
It would yes the ats 085.088.093 are all the same turbo, same cartridge same wheels, compressor housing is the same although 093 has a small tweak in the snout and the 1/8” npt hole for a waste gate
The difference is the exhaust housing, and piping of course
I document really well, so if you have any further questions feel free to ask I’m sure I have the pictures and answers
Austin86250
idaho
Ran it up and down the mountains yesterday for a couple hours still checks out I’m giving it a clean bill of health
sramasya
