Bad Glow Plug Circuit
Motorhome idi
Washington
Hey my controller is clicking and there is no power to any plugs. Im the second owner and i noticed that two wires look like they got cut right by the controller.. I don't know if thats it or because the rubber on the plug connectors crumbled off and theres no insulation... Idk what do yall think? Thanks for the help.
Motorhome idi
Washington
The starter is hooked up to the bolt the yellow wires should go. Should i just hook them up on top of the starter wire? My bad im 16 w no parents
Philip1
Northeastern Nevada
The 2 yellow wires are battery supply to the glowplugs. I would recommend getting some battery cable and use that to power the controller instead of reconnecting the yellow cables. The yellow cables have a bad habit of catching on fire over time as the connectors start to corrode.
