Shane1013
I picked up my 94’ crew cab for a what I think was a good deal at $2900. It has 229,000 miles and Looks like it was taken good care of mechanically. The only issue I’m having right now is a small miss at idle that seems to be after it warms up for a few that you notice it. It is still responsive and doesn’t miss when driving it. After it idles for a minute or so it will smoke white smoke and have that small miss. I’m not sure of the injector pump/ injectors last replacement, but they have been replaced in the life of the truck, the injection pump has a mid west pump sticker on it. It was leaking fuel from the return lines, but I replaced it with the return kit and no leaks whatsoever. It cranks nice and even and oil and antifreeze are both clean. I’m a mechanic, but haven’t played with diesels a whole lot. Any help would be appreciated.
