It is revolting how little I seem to have accomplished lately!!!
Sent out the injectors to a guy that specializes in rebuilding them for sled pullers. Guy at work that is pretty heavy into pulling hooked me up with him. Finally decided where to position my turbo, and spent a good amount of time Sunday night/monday morning building the elbow for it. figured up what I need for a new driveshaft and got the driveshaft place going on it. Had a potential oil cooler found on ebay, and contacted the seller but I dropped the ball on it and need to get back in touch with him. My friend got the radiator, shroud and electric fan all fabbed up,-forgot to get a picture of it.
heres a shot of the clutch master cylinder and adapter to bolt it to the existing holes.
Heres a shot of the elbow and turbo. I know it looks pretty hack fab on the outside but what you can't see is how many hours we spent tweaking the individual pieces that went into making it in order to smooth out the flow as much as possible. The rectangular piece that starts out of the exhaust manifold we actually made from scratch using 1/4 thick pieces cut from an old 2.5 ton military truck frame. I chose to run the turbo like this for various reasons-- the fresh air intake is pointed towards the drivers fender, where the large air filter will be. the compressed air outlet will shoot over the alternator and drop down to the intercooler. You can see the exhaust feed. the exhaust outlet will do a 90 and drop down then run along underneath the cab along the outside of the frame. There was no room to run it on the inside of the frame anyway, so it does work out better in this case. What worries me now is the extra leverage that will be exerted on the 4 bolts holding the elbow to the exhaust manifold because of the turbo hanging further away. Then factor in the weight of the exhaust, and the added torque movement from moving the turbo away from the centerline of the engine. I want to add some extra bracing to it, but there is nowhere on the block to do so. I could run something to the exhaust manifold bolts, but that wont gain much because it would not be adding strength in the proper plane of potential movement. The only realistic (but still not ideal) option I am coming up with is to build something off of the backside of the lower alternator mounting bolt- maybe still run something out from the exhaust manifold bolts too. Every little bit helps, or am i overthinking this???
Also started getting the fuel lines ran. I am not 100% shure on this, so somebody help me out here. feed line from the tank runs to the rearward side of primer/lift pump. Fuel then flows out the front of the primer/lift pump and feeds into the rear facing port on the fuel filter head. Fuel then comes back out of the filter head on the side opposite of the block and goes to the front top of the injector pump. fuel then returns to the tank from the rear of the row of injector feed fittings. Right?? Wrong????
Anybody know if there is a way to recalibrate the factory tach to use the bus tach sensor that reads the teeth on the flywheel??
