defecater
After starting to aquire parts about 2 years ago (and even selling the truck, then buying it back 6 months later), I finally got down to the job of physically putting the engine in yesterday. Truck is a 94 F-350 crewcab dually 2wd that had a 7.3 in it previously, that threw a rod in the spring of 2010. The engine is out of a 1990 bus. I bought the engine for $300, with the knowledge that it needed IP work. Engine was originally in front of an Allison automatic, but I am using a 5 speed transmission from 2.5 ton military 6x6 that has OD 5th gear. If memory serves me right, it is an 3053a Spicer.
I went into the project fully accepting that some cutting would be unavoidable to the firewall because of the large clutch housing to run the Spicer 5 speed. We actually had to lift the cab off the frame about 8 or so inches to get the engine and transmission in as one assembly. By measurements so far, it is looking like 3 inches of body lift will be a good idea, or I would have to cut clear up into the cowl/wiper linkage area. Also going to have to cut and re-fab the drivers side floor because of the big clutch housing. It might actually be a good thing though, because it might make a comfy rest for the drivers right foot while pedalling it down the interstate with no cruise control. Right now the truck is at a friends shop, because mine isnt large enough to be doing an engine swap like that on a truck that long. Once we get the sheetmetal cut and push the engine back some more, we will build the engine mounts, then it will come back to my place for finishing. His shop has ****-poor lighting, so no pictures untill it comes back home.
Other observations so far- going to either have to cut a hole in the crossmember for the fuel filter, or remote mount it. Leaning towards remote option because I really dont want to go hackin on the crossmember any more than I have to. Going to have to do something about the coolant filter too. Cut hole in crossmember or tap and plug the holes in the filter mount, or maybe tap the holes in the filter mount for lines to remote mount it. I am leaning towards just tapping and plugging it and doing without the coolant filter.
Can anybody advise me to the feasability of pulling the oil cooler off the side of the block and replumbing/refabbing it to use a remote mount fin and tube cooler mounted up front in the airflow??
Maybe someone can learn from my project, and I am damn shure going to need some questions answered to get this finished.
