defecater
Heres the combo hanging from the fork of my repowered Hough 4x4 wheel loader- I gutted all of the original powertrain and replaced it with a propane burning Ford 302 coupled to a C-6 transmission that was custom adapted to a Spicer gearbox from some kind of tree maintenance equipment that reversed the direction of rotation. From there a driveshaft feeds into a transfer case from a M37 (NP200) then it feeds to the axles. Hydraulics are powered by a pump driven off the front of the crank. Just proves this isn't my first unorthodox swap.
this picture shows the adapter ring I mentioned earlier. You cant tell, but there is a half inch taken off of the clutch housing(transmission side). For the adapter ring, if you look at the smaller diameter bolt pattern, it is now on a flush surface with the outer pattern- before machining, it was 3/8 inch further away from the engine. Clear as mud, right??
This picture shows how we left it after the first weekend of working on it. you can clearly see how high we had to lift the cab to get the engine and tranny in as one unit, and the back of the block is touching the firewall.
This shows the coolant filter head and how low it is- after cutting out the firewall and pushing back the engine, it will be right into the crossmember that you can see sloping downward to the left of the filter head. Before getting started cutting on the firewall last weekend, I went ahead and pulled the oil cooler from the block just to see what I would run into for making it a remote mount tube and fin unit- looks like just making some adapter flanges and plugging off the coolant passages. went to town(town is where everybody hates you, kids all try to beat you up!!) this afternoon and got two 1.5 inch freeze plugs for the coolant passages- they seem to fit as well as any freeze plug I have ever put in. Another idea a friend gave me was that he said he has never seen a coolant filter on and IH tractor oil cooler, so a person might be able to source one from a tractor application. I am in Iowa, so there are ag junkyards around, but they are awfully expensive for some reason, so I will give the remote mount cooler a shot.
