With @
Waystro needing an axle for pass side of a D50 and me having THREE D50's here, and Waystro and I agreed to a price to sell and so forth I took it upon myself to document the removal of parts down to the axle. I include a variety of images with measuring tape for sake of argument and help explain the size differences.
Bear with me as there will be two posts with near 30 images. I hope this helps the OP Jaed with his issue at hand.
Starting with two sockets...I am pointing to the 2 I will use. The other two are for a D35 and 10.25 Sterling....just sayin...got a couple of these specialized units as do many here on this board...do this crap long enough cheaper to own than rent or borrow.
Now onto the meat and potatoes..the axle in question is an 88 F250 SC axle I removed when I did my D60 SAS....here I already removed lockout hub external part.
Apparently SIZE matters
With the two clips removed I thread in two lockout hub bolts and slide out complete hub
For good measure...totally pun intended
The correct tool for D 50 ...THIS APPLICATION...
Spindle nut off and i socket
Two magnets make short work of lo king washer
Inner nut to do
And hub off spindle.....all done
More coming
Hope this helps..
