yes hx35. no carpet for me, i have too many 90 degree angles in my floor for a carpet to contour it. maybe a rubber mat later on. thi sweekend got the wood on the flat deck all bolted down with the trailer decking screws, and got the brake pedal lengthened and adjusted. nice to driv enow. worked on the clutch pedal too but its being a bit tricky. i cant lower it and push it back or i dont have anough throw on the pushrod, so i lenthened the lever arm on the right side, that didnt gain me enough travel. its not terrible to use in the stock position but a little further back and lower would be nice.
also, any near MI got a tilt steering column for sale? I got two fixed position ones i could trade as well? My column is a bit too low for leg clearance.
my dfeadline to have this thing roadworthy (to me that means everythig except interior minus the dash) is March 7th as i have some large items i need to pick up in toronto area. would need to do a shake down test run 2 days before the trip to make sure everyhting is ok, repair as necessary the day before. next weekend is a wash as inlaws are coming over, so i gotta get cracking. my plasma is still acting up, i cleared one issue but now the compressor is tunring on intermittently, i think its a contact issue. but i foudn a nbig hyole saw hit at home dpeot for 20 bucks with a 5" hole which i what i need to clearance the light fixture plates, so i shall do that tomorrow.
also, a favor to ask. does someone have the wiring diagram for the turn signal switch please? 91 truck
PS: firs time i ran the truck with the turbo on, im still starting it on ether and the whole shop gets smoked out, there was alot of sticky "chunks" and a thick, sticky soot on the exhaust housing outlet. Smelled of diesel and ether. Was this just because the engine was stone cold, no glow plugs? I dont THINK its oil, as the cold side wasnt wet and thats usually what goes if the return line is too small (i got 5/8). Not too concerned, just wondering. Usually these issues are solved by getting it nice and hot and going WOT lol
