LCAM-01XA
Oh you're using a factory '06 shaft? Then yeah, sure thing, run it how you have it. The reason why the t-case is desired to be as close to the trans as possible is cause of length of front shaft, it's easier to add carrier bearings as needed to the rear than to the front shaft. But that concern aside, there's no other good reason to shove the t-case into the trans tail - both the intermediate and the rear shafts should be parallel and nearly coaxial anyways, with the only offset between their axis coming from the length of the transfer case, and at the same rate the transfer case should be at the same angle as the transmission to ensure the joints at both ends of both shafts run at the same angles. This does indeed require dropping the case down more the further back you go, which will like you said affect your breakover angle - if the case is simply moved aft but not down that results in the steep rear shaft angle IDIoit mentioned.
Out of pure curiosity, how long are your shafts now?
