Here is a pic I robbed from somewhere.
Two ways you can do it. You can hook it back up normal. To do that, follow the labels.
If you want to bypass the controller, hook a 12v jumper to where it says ignition switch and then where the white wire is touch it to ground. That will turn the plugs on when the wire is grounded as long as it's grounded. That's usually where the push button for ground is.
Connections for the gps are labeled.
