got the rear brake lines ran up tothe master cyl and the fuel lines. I will moun the lift pump on the driver side since i dont want to cross over to the filter side and gfight with starter and downpipe clerarance issuesl Just run a line over the engine to the filter, and my return is on cyl 1 driver side. anyway.
waiting fo rmore copper nickle line to come in so i can finish the front brakes and plumb my line lock in.
painting the top rails of the flat bed today so i can lay the boards on and fasten em down. That iwll probably take me most of the night. other than that, put the V belts on, make small bracket for the facet lift pump-plumb that, run a cable form starter to the batteries in my passneger footwell, fill diffs, t case, trans engine with fluids, run a wire to the FSS from battery, and a trigger wire for starter, tighten down hanger bearing and install the two u joint caps for the jackshaft annnd, its good enough to roll to the new house on saturday!
im interested to see how it founds like with an open t3 flange blasting in your face standing infront of the truck. Probably very loud and cackly.
