thank you. will be super tight! tonight im finishing fastening the flatbed to the frame. just need to cut the 3/16 8" long 3" wide "legs" and i got two 5/8 bolts thru each of them to the side of the frame, 3 per side. should be pretty strong.
then fuel and brake lines.
i just dont know where the front brake splitter is supposed to be, on this 05 the block seems to be on the passenger side..but there is a plug in it not a cut brake line...strange..
a littel concerned about the bed rail to bed clearance. with the baords on it and me standing on it to simulate half the weight of a full tank, im almost 7" of clearance between tire and bed rail. Just seems a bit small, if i have a load and hit a bump...
a lift in the rear might be in the very near future. It has B code/dually springs, 4" stock blocks. but my rear driveshaft has perfect angles! i just have to move the hanger bearing over to the driver side about 3/4" to bring the driveshaft exactly in line. but the front part of the shaft is 4" down, the axle is 4 degrees pitched up, so its perfectly in parallel like the Dana driveline bible states to do.
fresh cut white oak, the guy who cut it for me said the wood turning black is jsut it reacting with the moisture...dunno..jsut dont want it to rot.
my new lowrider
this is the front splitter..
