Well here are the parts after coming out of the oven.
I set up to shoot some primer on them and found out my primer was bad. [emoji35]. A trip to TSC for some primer and now I have grey parts.
I wanted to get the black on them but couldn't get it dried fast enough. I didn't want to be tending the fire all night. So I pulled my "new" tilt cruise column off the shelf and started getting it ready to swap in my stuff and I realize that one of the bearings is bad and the snap ring at the top is missing. [emoji35]
So this happened.
I tore it all down. Figured out which bearing was bad an in the mean time, I'll clean it all up and put fresh grease everywhere. Hopefully I can get it all back together correctly with my ignition cylinder and cruise working. I'm considering putting a fresh turn signal switch in while I have it apart because unlike a non-tilt column it seems you have to tear it all down to change it. The connector won't pass through the tilt mechanism like I remember doing on my 88 non-tilt years ago. Another while I'm in here. The set of 83 shop manuals Dad gave me saved my butt again on this one to figure out how to remove the pivot pins. So now I'll get a bearing ordered, and start cleaning and reassembling and the column will be ready to go back in.
