Progress....finally. Well, I spent the afternoon changing the media out in the blast cabinet and cleaning the windows. That makes things go so much better. 50lbs of fresh black beauty and off I went. I tore down all the various body mounts I've accumulated and matched them up to the new bushings. After a few minutes of head scratching, I chose the best parts (thank you IDIoit and Kenny) the west coast parts it was. In case you are wondering, this is how you take the core support mounts apart.
Clamp it all together and the impact gun makes really quick work of it.
I blasted them all up along with some other odds and ends.
Then zinc plated all of it.
Tossed them in the oven to bake and I'll paint them up when I get a minute.
I also fixed my wood stove which was smoking horrifically. Pipe was mostly plugged up. Wife said I looked like I'd been in a fire. I said, well sorta.
After all that, I started to tear down my steering column. Pulled the steering wheel and extracted my ignition switch from it since its new and it's keyed to the doors. Need to get the new to me column down and swap parts around.
Stainless brake lines are ordered. The rest of the brake parts are about to be ordered. Need to pull the hub on the right rear and figure out what I need to fix that axle seal leak.
More to come.
