Honda bumper
93turbo_animal
Marengo,Ohio
well just about done I'm going to cut some holes in the front for vents and mount a plug for the block heater then paint ;Sweet
sle2115
NRA LIFE MEMBER
Southeast Ohio
WOW!!! Looks great dude, but I then again, I knew it would!!! ;Sweet ;Sweet
I think you are going to need some bigger saw horses though! That thing looks "tough" and it may start chewing on those wood horses! LOL
93turbo_animal
Marengo,Ohio
Yea my dad thru those saw horses together real fast one day for something and we just kept using them but about every time I used them I had to add more braces and screws to keep them together but they are pretty good now but I leave the chain hoist attached for safety
sle2115
NRA LIFE MEMBER
Southeast Ohio
:) I just figured a bumper that mean looking would start chewing on them during a quiet evening in the shop!!! :rotflmao
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
TUFF!,..Looks great Aric, Nice work.
Might I suggest for painting or covering it to go with Bedliner material. My brother Dave has it done on his Moose Bar, Looks great.
Later,
Darrin
93turbo_animal
Marengo,Ohio
Ok done fabricating finally got the vents in for ya Rob and got my block heater plug in figured out
Thanks Darrin I'm going to use the spray on bedliner like what was on the bottom of my truck at the IDI rally but I went ahead since good ole oil base paint is a lot cheaper then the liner I painted it for some extra rust prevention and all of the back since it would be a waste to use the liner back there
tuckerd1 I took the scales out tonight just before I painted it and as it sits it weighs 185lbs which I didn't think was to bad considering its all 1/4" plate and sch 40 pipe I weighed the factory bumper and it weighs 65lbs by itself
sle2115
NRA LIFE MEMBER
Southeast Ohio
Looks great. Would the bed liner stuff help on the back to keep it from rusting? I have some stuff called "zero rust" that works pretty well also. I used it on my flat bed and then coated the top with spray on bed liner. Seems to be holding really well. Maybe it was overkill to spray underneath with the bed liner, but figured it would be a good sound deadner as well.
Either way, it will look cool I am sure.
Scott
F350camper
BOOST!
USA
Man that looks really good Aric. Nice work! So what's left? Just mount it up and start pushing hondas?
93turbo_animal
Marengo,Ohio
Finally got the bedliner sprayed on and got the bumper mounted and the lights wired up all done now I think I'm going to look into powdercoating now
