i got bored and decided to upload pics now lol. here they are.....
return from the reg is the one with the plastic loom on it...
another pic of it..
relay mounted to the drivers side inner fender. the ground with the yellow connector is the e-pumps ground, i wanted a solid ground that would stay CLEAN for that baby...
some more of the relay...tapped into the main power feed for the fuse box for my constant 12VDC for the pump relay...
inline fuse for the constant 12VDC power...
swtiched 12VDC mooching off the FSS...
supply line from frame rail.....
supply line into the regulator...
New fitting for the reg>filter head. much better than what i had before....3/8" NPT>1/4"NPT...
the e-pump mounted to the frame rail right behind the trans cross-member....
'bout it for now. when i get my fuel pressure gauge mounted i will post a pic of that as well. it is all wired up, just waiting on the mounting cup.
i have that plastic loom stuff on all the rubber fuel hose and all(as much as possible) wiring. i even went as far as running the wire for my pressure gauge in with the FACTORY engine harness
. it was actually easier than i though it would be and didn't take long at all. it took me probly an hour and a half to install everything for the pressure gauge on monday, but that is because while looking for matches(no cig lighter) for the heat shrink tubing, i stumbled upon some fire crackers. they had my name written all over them. needless to say the truck got put on hold for a few min
