a perplexing problem recently occurred. Still got the S366 on the engine, no axial play, but started noticing alot of blue smoke while idling. I go to drain my catch can and the thing pours out almost 2 quarts, way over its capacity. Also all my seals started leaking. Ok, so it filled up all the way plugged the crankcase vent and started blowing seals.
However, I used to be able to go almost a month (same amount o f driving) and only drain 1/2 a cup from it. Now this thing almost emptied out my oil pan in a week! i take the charge piping off, run it at idle and i see oil slobbering out into the compressor outlet. Rev it up and it ***** oil out. Ok so its leaking...but why?
It was fine for 15k miles, there is no crankcase restriction. Its a -4 line no restrictor. I can put a restrictor in there..but if it was oil pressure or volume issue..wouldnt this have shown itself in the first few miles of turbo install?
These turbos dont have a paper gaskets, its a steel circlip ring, so it cant just get blown out.
