ironworker40
NYC Ironworker
If you have an electric pump and can of fuel hooked up then shrader valve at the filter should show fuel no air. How do you have this hooked to truck? You are not trying to push fuel through mechanical pump are you? You said can is sucking in. Were is the fuel going? If you are trying to push through mechanical pump check your oil level you may be filling the cranckcase with fuel. Get filter full and tighten injector lines. Crank with full batteries and charger hooked up so it spins fast. Crack one line at a time. Plug in block heater if you have coolant in it for a few hours before you try it this will help light it off.
