ZF-5 transmission and SMF setup, poss. trade for 6.9/7.3 engine
MoonDog
Portland, OR
I picked this stuff up to put in my '88 diesel, and as fate would have it I came across a 4x4 truck that I'm going to build into a tow rig instead.
The transmission came out of a '96 powerstroke and is the higher torque model of the ZF-5. I have the shifter, clutch fork, throwout bearing, and dust cover for it. I'd like to get $600 for it.
I also yanked a single mass flywheel out of the truck along with the clutch disk and pressure plate which looked good enough that I was going to put them in my truck and run them. The flywheel has no grooving or heat discoloration. $200
I'm going to be swapping out a 460 in a '90 F350, so I'd be interested in trades for a good running 6.9 or 7.3 IDI engine, especially if there was turbo stuff to go along with it!
http://picasaweb.google.com/moondogie/ZF5?authkey=Gv1sRgCJ26pu68ufLMoAE&feat=directlink
