WTB 92-97 F350/Superduty Brake pedal
quincyj34
Pensacola
Looking for a brake pedal off an auto truck. There arent any 1 ton at my local yards so Im kinda in a bind. I really could use the help.
FarmerFrank
Blairsville, Pa
So you need a regular auto pedal or a hydroboost pedal?
I'm about 94% positive JUST the pedal is the same from older models. Either way I have both.
quincyj34
Pensacola
the hydroboost for a truck with an automatic....the pin location is a little different between the two.
FarmerFrank
Blairsville, Pa
Correct. Hydraboost. Pretty sure I only have standard hydra pedals.
I'm pretty sure one from an older model will work if you change only the pedal
