Wow....
Question is: How do you re-manufacture a casting? Repair bolt holes in a casting? How can you %$#* up bolt holes? But it is nice and shinny, aluminium gets that way when it's knocked to beat hell with glass beads.
pt_Ranger_v8
Vegas
I wonder if it has the new super strength spark plug holes. So you can 'preheat' the air before it hits the pre-combustion chamber :p
flareside_thun
Reviving The General Tao
Tavares, Florida
The worst part is is that he labels himself as an engine rebuilder business...Stay the hell away from my crap.
Compu Doc
Middletown NJ
Maybe that's for that carbureted diesel I keep hearing about. LOL!
It sure is. Just so you know to make it easier I indicated where the carburetor is with the yellow arrow. I'd say that's a steal complete with the carburetor. Someone should email that guy and let him know how rare that manifold is. I'd hate for him to find out after he sold it. Anyone seen a grown man cry? :rotflmao
That number is molded on the casting, must be right. Here is all the Navistar numbers for the IDI and IDIT. Click on the URL
[PDF] Navistar IDI & IDITFile Format: PDF/Adobe Acrobat - Quick View
Navistar Indirect Injected (IDI & IDIT) 6.9L/7.3L Engines. Complete Drop-Ins ...... 1804357C4. 1983-94. Manifold, Intake, 6.9L/7.3L, International ...
www.diesel-connection.com/documents/remanAppNPrice.pdf
N 1 RV1805241C1J 1805241C1 1983-94 Bolt, Intake Screen, 6.9L/7.3L, International No Core $4.00
N 2 RV1805055C2J 1805055C2 1983-94 Gasket, Exhaust, 6.9L/7.3L, International No Core $9.00
N 1 RV1813067C92J 1813067C92 1983-94 Gasket, Valley Pan, 6.9L/7.3L, International No Core $41.00
N 1 RV1805054C3J 1805054C3 1983-94 Manifold, Exhaust, Left, 6.9L/7.3L, International No Core $59.00
N 1 RV1800708C2J 1800708C2 1983-94 Manifold, Exhaust, Right, 6.9L/7.3L, International No Core $59.00
N 1 RV1804357C4J 1804357C4 1983-94 Manifold, Intake, 6.9L/7.3L, International No Core $176.00
N 1 RV1805240C1J 1805240C1 1983-94 Screen, Intake, 6.9L/7.3L, International No Core $4.00
N 1 RV1804288C1J 1804288C1 1983-94 Strap, 6.9L/7.3L, International No Core $4.00
1. Kit contains the following gaskets: 2 cylinder head, 2 exhaust manifold, 1 front header oil cooler, 1 fuel pump mounting, 1 left front crankcase cover, 1 oil filter adapter, 1 oil
pan, 1 oil pump inlet tube, 1 rear cover, 1 right front crankcase cover, 1 ring seal, 1 thermostat, 1 timing cover seal, 2 valve cover, 1 valve cover nut washer, 1 water inlet, 1
water pump, and all applicable o-rings.
International Truck
Manifolds & Components
Confidential & Proprietary 05FIPRICE-B 4/4/05 TD
Navistar Indirect Injected (IDI) 6.9L/7.3L Subassemblies and Component Parts
Ford E & F Series
rjjp
Needs to go test
Clare, Mi
Hmmm, if the list that oldbull8 posted is current, the you can buy a new manifold for 176 where as this **** wants 250...
