Would you rebuild this?
oworm
Indianapolis IN
This was out of an 87. Got one of the heads off and took some pics. It had a broken head bolt but we got it out.
Your head is shot. The valves were sunk too deep and now the seats are gone. The exhaust seats are replaceable but the intakes are part of the head. Someone has done a valve job possibiley several times on this head... Ot just once but very badly. You have not said if this is a 6.9 or 7.3. I'm thinking it a 7.3 so it will be best to sleeve it. Boring it 20 over and you take a big chance of early cavitation. A 6.9 can easily be bored 20 over and no issues with cavitation.
I just noticed in one of the block pictures that this is a 6.9 block. Look closely at the pic showing the lower corner of the block. there is a triangle coolant passage. these are only found on the 6.9 blocks. The 7.3 blocks have a round coolant passage blocked off with a freeze plug in the head and block... We should remove those when the heads are off. I know of no reason for them being plugged up other than running the coolant hotter thru the heads for emmissions requirements....
hesutton
The Anti-Anderson
Bowling Green, KY
I'm with Gary. Why are the exhaust valves so far out away from the seat/head? That's strange. The block (6.9 right?) seems rebuildable. The heads need to be taken to a good machine shop to see if they are or not.
Heath
oworm
Indianapolis IN
It is in fact a 6.9 87 motor. I think they had the 7.3 rockers. The only reason I bought this is because my 84 has a cracked block. (Common problem for the early 6.9 blocks)
The 84 runs like a champ and uses very little oil and blows zero smoke even at high throttle. What I might do is get the 87 block hot tanked and rebored and put everything from the 84 into it. Will I need to get oversized pistons? Do you think I couild get away with honing the bores?
hesutton
The Anti-Anderson
Bowling Green, KY
It just depends on how deep the irregularities are in the cylinders. It may take more than just a honing. The block needs to be cleaned up and see how bad the damage is then. It may require a few thousands to get those defects out of the bores.
Heath
88beast
pa
you wanna hot tank it take it to the machine shop and get it tanked then have them look it over too pics are great but we cant tell you just by pics what will need done as we have no measurements for all you know it could have bored out already and will need sleeved so just find a good shop and have them look at it
This is a hope... If its not been bored out to 40 or farther you can bore it and be fine seeing its a 6.9 block. No need for sleeves unless its bored out past 40. The over size if any will be stamped in the top of the pistons. Or they will have an A, B, C, D, size fitment mark.
trapper
Boom Boom
Chatsworth Georgia
Mine looked like this
and ended looking like this with some work ;Sweet
It is amazing what a .002 power hone will clean up, also the intake depth may be an illusion, really hard to tell without measuring.
oworm
Indianapolis IN
The guy who took the head off said nothing about the head. He was more concerned that there was a broken head bolt.
h2odrx
Anti-O
Coastal Neckville, NC
Clean it up get some measurements and let us know, but if yours runs great, I'm guessing the block is cracked by the heater? you could take the 2 and make one....
oworm
Indianapolis IN
I bit the bullet and got me one of these
I got a little money an decided on a Jasper reman.
GaryB
