I appreciate the help, I was thinking that smoke was just the engine burning up oil that might be getting past the rings. If its fuel, then at least there's hope for the IP, although anyone seeing that fuel solenoid switch can't possibly think this things actually rebuilt.
I'll play with the wiring again, maybe I've got a bad connection or something, but if I did, I think it would click in and out rather than simply say its ready to start.
I'm investigating a hot box, it couldn't be any simpler, on or off, indicator light, Nichrome wire element would around an old ceramic from a used toaster, gauged for length and voltage to give me proper temp, placed under the top of the air filter. That way I can just eliminate the glow plug problem entirely, no possibility of blown plugs, no worries about faulty circuits or controllers. Oh I'll play with it a little bit, but if its to much torture, the glow plugs are gone. I can add about 1K watts of heating element and be at about the same temp range as the glow plugs. If I remember this is what cummins does on there larger units.
Once I get the start issue solved, its on to the forever leaking return fuel system. I think I'be blown maybe 2 or 3 hundred on that so far, and still it leaks like a sieve. My bet is there must be some way to just weld the weep holes closed on the injectors and eliminate the whole system entirely. I can't imagine any serious gear head putting up with that nonsense forever.
