Wiring questions
ClemsonIDI
SC
I have a couple issues I'd like to try and figure out so I'll just post them all here.
1. This past weekend I went after my rear abs light that's been on since I bogot the truck. I replaced the wheelast speed sensor on the rear diff. The light went out, but now it's back on. Any ideas?
2. My windshield wipers only work on the fastest speed. I have the variable speed switch, which I already replaced. Maybe a bad relay?
3. My water temp sensor doesn't work properly. As seen in the picture even while sitting in rush hour traffic it never moves further towarda the hot side than it is there. I grounded the wire that goes to the sending unit and it moved to the same position as seen here. I used a test light to ground it and the light came on, but it was dim. What can I do to test further. I plan on adding some after market gauges soon, but I still would like for the factory one to work as it should.
Thanks,
Joey
1. Look up how to get the codes.
2. Wiper delay module.
3. Get a real gauge. Factory will never be accurate enough to trust.
