wiring help
1466IH
waterloo, il
hello all its been a while but im in a dilema im about 150 miles from home and need a schematic of the ignition module so i can see which wire to tie together to get this thing started the truck is my 89w/ e4od if that matters but local prts store says they cant have the new module till monday but i have to be home before then
1466IH
waterloo, il
it was the ingnition switch i was on the side of the and the trick died like i turned the key off so i did some quick investigations and just cut the wires off the back of the switch, traced the start solenoid wire so i could leave it out and wirenutted the rest together then use a screwdriver and jumped the solenoid on pass fender and dont say fire last winter my headlight caught fire drivin down the road lol its pretty bad when the service truck is down lol thanks for the help and would you have a scematic i think i am going to do away with the key altogether and run a series of switches and a pushbutton
Caterpillar335
