1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
wiring diagram for 1989 ford 7.3 IDI
Discussion in '7.3L Powerstroke Diesels' started by Dan Keating, Oct 19, 2020.
  1. Dan Keating
    Dan Keating Registered User
    Oct 19, 2020
    NY
    I am looking for a wiring diagram specific to the fuel system. I am looking to to take out the fuel tank switch and just run one tank and reconnect the the fuel gauge. any suggestions?
  2. greenskeeper
    greenskeeper Full Access Member
    746
    93
    Mar 16, 2013
    hatfield pa
    I'd guess that the harness at the tank selector is what you'd need to rewire. Determine which pair of wires goes to the sender for the tank that you are going to keep and wire those directly to the sender in that tank. In the cab you could eliminate the selector switch in the same way. Should be pretty straight forwards IMO.
Share This Page
