Will Not Start
84ord
Courtenay B.C.
Here's whats happening. I changed the IP and have bled all the lines. Tighten down the lines and it wont start.
Drain my batteries trying. Get the charger out and cherge it and still wont
It seems like the starter it is drawing to much power? The batteries are good I charge them and crank it 2 shots of five turnovers and it dead again?
Whats the deal?????????? :confused:
94f450sd
somewhere,ma
sounds like either your batteries are junk or your starter is junk.when it turns over does spin fast or slow?an IDI is gonna be a mother to stat if its spinning over slow.
sassyrel
iowa
if its a stick--and you pull it a few feet and its starts--most likely your starters junk--aint spinning fast enough--
