BrianX128
Yeah, I'm just realizing how many of my wiring decisions over the years would have been easier with diodes. I've used so many relays ran from remote toggle switches to imitate what a diode would do.
Like fog lights that can come on manually by a toggle switch in the cab to run with running lights but not activate headlights, but also triggered by a low beam wire only with headlight switch automatically. I'd traditionally use two 4 prong relays, one from a remote switch in the cab and one spliced into the "trip wire" of the low beams that way my manual switch in the cab doesn't feed the low beams as well (so I could have fog lights with no headlights if I choose to around dusk with all my Amber running lights on, etc, but still have a relay control the fogs to be on with low beams and off with high beams like normal). I've basically been creating a logical diode effect by using multiple relays for things in wiring knowing that the "hot" leads coming out of a relay to power the accessories on the other end don't allow the electricity to flow back through the other way into the "signal activator" for said relay.
Basically I have a lot of relays. It works, same fundamental idea in the end with stuff, just a lot of relays. Haha.
Furthermore, I now have some clarity for the original project at hand but have now thought of 12 other things I'd like to do as well. Time to order a crap ton of diodes relays wires and toggle switches. My light obsession on vehicles never ends.
