alienturtle
Human
this is the motor that came out of my 89 f250..it is the 7.3l motor. i will be doing a cummins swap so i dont need any of the parts from the 7.3l I have EVERYTHING!
Injection pump
Injection Lines painted high heat black
Intake man. painted high heat silver
CDR
valve covers. painted high heat silver
oil pan. been hot tanked and cleaned.
newer lift pump with 2k miles or so on it..
set of 8 glow plugs..truck always fired up every cold morning
set of 8 injectors. 6 BB code 1 C code 1 D code..but they all had re manufactured bands on them back in 08 so im guessing all the tips are the same
Injection pump cover with oil fill built in..painted high heat silver..includes tach sensor
water pump, fan pulley and fan.
power steering pump..no leaks worked fine..
all new belts.. put on like 700 miles ago
fuel filter head
both headers..cleaned and painted with 2000 degrees paint
I have every accessory bracket for it..all have been hot tanked cleaned and painted high heat silver..some high heat black.
Entire 7.3l Block with crank rods and pistons still installed.. supposed to have around 80k on re man but 1 piston looks bad but cylinder walls look good. and ran without a hickup before pulled for a reseal.
might have more i cant think about..let me know if you need anything else. THIS IS ALL MAKE OFFER..i dont know what its worth so i trust you guys to make a decent offer to a fellow OB member. I live in Ripon California.. if you want to come take a look at the heavier stuff...Im willing to ship but you will have to cover the charge..thanks guys
vacuum pump SOLD
turbo kit SOLD
bottom crank pulleys SOLD
bottom fuel filter housing bowl SOLD
Complete Victor Reinz Engine gasket kit SOLD
Both heads and all valves SOLD
#1 hard injection line w/sensor SOLD
Glow plug relay and controller w/wiring harness SOLD
Some random pics
Injection pump
CDR
fuel filter head
vacuum pump SOLD
turbo kit SOLD
Some random pics
