It works like a cam and lifter. It has a metal eccentric that pushes up on a lifter like thing. Without oil it would grind up quicklywhy would you put oil in it? bearings are sealed units. oil in the pump will only deteriorate the diaghram, possibly void your warranty if they inspected after failure. if you wanted to lube it maybe some silicone spray?
