what do you use to replace the stock fuel lines with?
hjalbert
I want to do away with the stock lines, all the way back to the tanks. I was wondering what type of line others had used. Thanks
Exekiel69
I assume you are talking about the rubber fuel lines, I got fuel injection hose off of evilbay. All good so far and I burn veggy.
sle2115
NRA LIFE MEMBER
Southeast Ohio
Well, call me stupid, but I used Russell Pro Flex. NOT CHEAP by any means, but should hold up to anything I run through it.
hjalbert
Yeah, I am talking about rubber, but I want to replace fords lines all together, the semi hard ones also. I fear that they were only meant to last so long, and that any moment I will develope an air leak. I saw a picture of another members set up, and probalbly willl do the same as him running 3/8s alum line, and use fuel injection line where I need to connect to the selector valve, and my pump and stuff. Thanks!
dancrowley
danc01
south of Boston
Fuel lines
I replaced all my fuel and brake lines with stainless steel lines. I sent my old lines to Classic Tube in New York and they copyed themon a computer. The lines fit perfect and total cost for all the lines was $450.00 a little pricey but I'll never have to mess with them again. Depending what year your truck is they may already have the specs. Dan
h2odrx
Anti-O
Coastal Neckville, NC
Hey Dan welcome!
Fill in you Sign about your truck?
crispy74
