What alls needed for a d60 swap
83ford
ford diesel baby
calico rock.arkansas.us
Ok I'm soon to do a d60 swap in my 86 and I have a d50 under it at the moment.ive got the stock f350 front springs and tie rods what else so I need and we're is a good cheep place to buy parts for it.it was 100 bucks for the ball joints at the parts store for the cheep ones.im sure I'll need something that I ain't got and would like to not spend a but load because I've got 2 other trucks that need stuff also.and will I need to shorten the drive shaft in the front end.thanks yall
Sent from my Iphone using Tapatalk
Could've got spicer balljoints for cheaper.
You need the double Cardone F350 front shaft.
83ford
ford diesel baby
The do what lol.i can probley get it from my boss since I got the transfer case and rear drive shaft from him outta f350
83ford
ford diesel baby
Ok sweet thank ya also is there some kinda bar that comes off the frame to the axle
D60 swap
Springs
Shocks 2" longer n f250 iirc
Pitman arm
Steering linkages
Track bar and track bar mount
Double cardan drive shaft
Cross member if it is a zf ...different than 250 cross member...dont know bout E4ODs sorry
That bout sums it up.
Hope uou have a BJ 60 not King pin
83ford
ford diesel baby
It is a ball joint and why a new cross me ever but I have a t19 and I've got the springs and tierod bars and stuff.so I need a new pitman are also?
If you have a ZF you need an f350 x member as it has a large droop for the front drive shaft due to increase in ride height. Same reason for double carda drive shaft.
As for T19 C6 or E4OD I personally couldnt say however I would imagine so.
Pitmam arm is longer for F350 so again this affects steering geometry.
Yer choice
You aksed I amswered
mblaney
Ottawa/Ont/Canada
Check the write up in my signature. I worried all these details and put all the answers in the thread about my swap.
