Weight of 2001 F-350 X-Cab Dually.....
Conn
Offroad Jeep Dude
So.....we got the dandy job of installing a ring and pinion in an 01 tomorrow, and my shop lift is rated at 9000 lbs. I've had my 89 F-250 ext cab diesel on it, a cadillac escalade, surburban, and a 2500 reg. cab cummins....am i pushing it by putting this thing on the lift? I'm not looking forward to installing that pig on the ground...
Anyone have any wet weight specs on an 01 Supercab PSD dually 4x4?
Thanks!
Conn
Mike
Stroker
Cora
I dont have the figures but that thing will weigh in somewhere between 7800 and 8500 lbs.
jlayne
Bondo Bandito
Milledgeville, GA
my buddy bent his two post with a reg. cab dually PSD 4x4... not sure what it was rated at but it was a mess... 9K should handle it fine but i would keep a good eye on it
Conn
Offroad Jeep Dude
well, it's on the rack, and it sure is a heavy mo-sucka.....i've only got it about 2 fet off the ground. it's a little tippy and I don't want to get it too high in the air.
thanks guys!
Conn
Max Power
I've lifted quite a few crew cab duallys of all brands with my lift that is rated for 9000lbs. You should be fine.
