82F100SWB
Well, I finally mocked up my turbo on my buddy's spare 7.3 so I could measure up for the oil feed lines, and got them made up today, then I decided that I was done fooling around, and that the turbo was going on my truck today...
It turns out that even though my turbo came off of an E4OD equipped truck, and had been initially installed on that truck, the y-pipe fits my 4 speed truck just fine.
I must say, those of you who have installed turbos on trucks without a body lift
I can only imagine what it's like to not have any room whatsoever to do that install. Now that I have it on, come the spring, I'm re-building that y-pipe and uppipe, I have absolutely no need for that crimped section that would normally sit between the firewall and the bellhousing, and, if I folded the pinch weld, I'd probably have room for a 4" down pipe....
All in all, I have to say that probably the most difficult part of the whole job was tightening down the nuts that hold the turbo to it's pedestal, and removing the stock exhaust system... Getting the nuts off to remove the stock y-pipe was a matter of heat them up cherry red, get 3/4's of a turn on them heat them again, and so on... After all that trouble, I went and buggered up the threads on the drivers side studs during re-assembly...
Ah well.. Other than an exhaust leak at the drivers side manifold, I seem to have it all nice 'N tight...
Now I just need to get my gauges installed... My pyro is still in the truck that this turbo kit came from, and my boost gauge isn't here yet...
Still, I have LOTS of respect for anyone who has done one of these on a truck without a body lift. That must be extremely tight, I know I had fun getting my hands in to tighten bolts and such.
