turbo install???
zpd307
Zumbrota, MN
this relates to the glow plug relay. i printed off a copy of ats 093 install instructions. i am still a bit fuzzy on what to do with the gpr. does it need to be moved or just the wires covered with heat wrap. when i went junk yarding a little while ago, i found a factory 93 turbo and the gpr was on a bracket on the passenger side valve cover. i was thinking about making a bracket to fit in the same area as the factory gpr on the 93-94's. any advice......
Dirtleg
Cloverdale VA
I did exactly what you are thinking about doing. I made a plate to sandwhich the oil dipstick tube bracket (the one over the valve cover) between the GP relay and the plate. Been like that for a year now with no issues at all.
zpd307
Zumbrota, MN
did you move the rest of the wiring that wraps around the backside of the motor, or did you just wrap it, or just left it where it was?
