Turbo From a Power stroke on an IDI
allan3306
ontario,canada
This probably has been asked before but can a complete turbo set up from a 97 power stroke (i.e intake, hoses , exhaust manifolds and pipes , turbo and mounting plate) be used on an idi and if so could some one PLEASE answer. The reason is i have ALL the components to do the add on just not sure how to supply oil to the turbo as there is no provision on the idi block that i can see to use the stock mounting plate. If someone could point me in the right direction i would greatly appreciate it . THANKS IN ADVANCE :hail
zpd307
Zumbrota, MN
X2 on that. not a bolt on affair. anything is possible if you know how to fabricate.
flatlander
plays dirty when losing
ft. wayne IN
The only part of that that you wouldn't have to fab is the turbo itself. You'd need clamps from Ford to make the air connections, machine a manifold for the oil inlet/return, fab the exhaust and intake pipes, etc. . .Other than that it's a piece of cake.
allan3306
ontario,canada
So fare this is not looking so good any more. maybe i'll go back to my original idea of a remote mounted turbo. I say this only because i have a couple turbos from an old street rod i had so why spend money on somhing i have and just need to make it work.
hesutton
The Anti-Anderson
Bowling Green, KY
Remote mounting can bring other issues.......the biggest being oil supply to and from the turbo. You may need a separate oil system to keep the turbo lubed.
Heath
truckonfire
