Truck running weird
Meads98
Norfolk va
I have a 1991 f350 with a 7.3 idi that I'm currently road tripping. Truck had been ran intermittently for several years.
About 4 hours into my drive the fuel filter light started coming in and out. Usually comes in at higher RPMs and drops out when I go below 2k. I might just be paranoid but it also feels like it's losing power for a second then comes back for a second then drops again. The power drop isn't consistent but frequent enough to be worrying. I've switched tanks multiple times and it doesn't go away so it make me want to rule out a bad pickup unit.
My main concern is that it's my lift pump going out. Any thoughts?
Edits as the come up: it has a brand new fuel filter but the diesel in the tanks has been sitting for a while.
It does sound like "mild fuel starvation"..... either the lift pump is slightly compromised or the fuel filter needs replacing.......im betting on the fuel filter......
Meads98
Norfolk va
Ill add this to my original post but it does have a brand new fuel filter. The diesel in it is years old so maybe it's a little gunked up already?
Entirely possible. Fill er up with fresh diesel and some sort of biocide, replace the filter again and go drive er some more.
Fuel filter light means theres a vacuum detected at the filter, which means its getting clogged up.
Meads98
Norfolk va
Okay I'll give that a go. Anyways to rule out the lift pump before I get back on the road? My biggest fear is that the lift pump completely goes out and then I can't get it up on a trailer easily and I've still got a long way to get home
Not really, if its pumping.... its pumping.... if you had a fuel pressure gauge, you might could tell something...... but ultimately it sounds like your "out running your fuel", so do what Nero said with some biocide and just slow down a bit..... put on some tunes(or preaching if your like me) and just cruise..... take it easy, dont let the sound of your own wheels drive you crazy......lighten up while you still can......lol...
Meads98
Norfolk va
Meads98
Norfolk va
Yeah I'll give that a go I guess. The drive to AutoZone was fine. No light or fuel cutting out but I also didn't really get above 2k. My only fear is this is the last big town I can get a U-Haul for the next couple hours and I still have 2,000 miles to drive
