transmission programming and GV type overdrive?
res0wc18
Everett,Wa
So guys who has an aux overdrive on their power stroke? How does the shifting work? If i left the truck in drive and took off would the gear vendors or other aux od shift between and split each gear? How does that work?
Also does any one know who does the live tuning type programming? My transmission has that banks trans command on it and sometimes it shifts great and other times it shifts way to early and hard?
bfife
South Dakota
There are two aux O/D on the market. GearVendor and US Gear Dual Range. I have owned both in a PSD. The GV unit is a small single piston automatic tranny. In Auto mode it will upshift into "overdrive" around 50 mph and down shift out at 25. It will not operate below 25 mph because it is not building enough pressure to shift or hold the clutch pack in place. It does not like Exhaust brakes or downshifting because it won't take the "reverse torque".
The US Gear unit is a small electrically shifted manual tranny. It will operate at any speed and exhaust brakes and down shifting are not an issue.
The GV unit mounts behind the tranny and or T/case and as such will only work in 2wd and not in reverse. The USG mounts between the tranny and T/case and will function in 4 or 2wd and forward or reverse.
Either one will work with both automatic and manual trannys. neither will "split shift"by themselves but you can do that manually by toggling the switch. the GV unit is much more sensitive to abuse and maintanence. it uses a special GM oil that is fairly expensive and they recommend oil changes ever 5000 miles if you tow alot.
USG use reg or syn gear oil and service as required. the USG unit has a higher tow rating and the warranty doesn't have any restrictions about weights or commercial use.
hope this helps. like I said before I've owned them both. The GV unit was OK but when I went to order one for my current truck the GV tech said he really didn't want to sell me one cause my truck had "too much" power. Its a mostly stock F550! the USG unit has been absolutely flawless for the last 30,000 miles towing a 15,000lb 5th wheel around the country.
Barney
ameristar1
The One Blue Thing
Steger, Illinois
DP Tuner is the one you want to get in touch with for the live tuning. Jody has a nice touch with the PSDs and if you need their info, they advertise here.
bfife
South Dakota
There are several tuners that can do live tuning. Bill at PowerHungry has been doing it for 12 yrs. Tony Wildman is also great. Jody at DP does a good job. Dennis, Matt, Ryan just to name a few more. Or you can order the Minotor software from PHP and tune it yourself.
Barney
res0wc18
Everett,Wa
the problem is us gear no longer is making them, and they say they may not ever again!
I had an 90 with the us gear and loved it
bfife
South Dakota
That's interesting. Are you sure? I'm talking about the Dual Range Aux Tranny. I know USG made that one and the VDO. I bought mine in June 07. not doubting you, but man I'd hate to lose this option. I tried to call the factory but its too late on a Friday. they still show them on their website with part #s and price schedule. Of course it hasn't been updated since June 08.
Barney
res0wc18
Everett,Wa
yes i am sure, when i first bought my truck i emailed them to get a quote and they dont have anything available period. That is what they told me this time last year. The said they were also uncertain weather they were going to continue to make anything for our "old" trucks!
Bo17
