well tonight i went to pick up some movies from the rental store. when i was leaving the store i pulled out onto the highway at a idle and decided to manually shift it through the gears so i pulled it down into L1 and it shifted down a gear. i thought this was strange so i came to a stop and put it back in drive and let my foot off the brake and idled for a couple feet and put it back in L1 again and it preceeded to down shift again. the next time i tried it the same way but i started off in L2 and rolled for another two feet and shifted down to L1 and it shifted down a gear. what would be causing it to start off in 2nd and not 1st? ive changed just about everything electrical and made sure the fipl is adjusted and the mlps is brand new and adjusted proper. if i start off in L1 and shift it through the gears it does fine.
