Towing issue with a 06....
jharvey
Shutter Bug
Georgia
What causes the Trailer Disconnected message? Using my brothers 06 F350, Auto, built in TBC, towing roughly 6k today the message center and the TBC kept throwing the Trailer Disconnected message, never did clear, brakes worked, light and signals worked. Put on a new 2 5/16 ball still got the message. All day and it's quite annoying.
Where do I need to start looking for the problem.
Thanks
John
jharvey
Shutter Bug
Georgia
Well I'm pretty sure it's not on the truck end and the trailer did it with my truck today as well. Trailer needs a complete re-wire and brake job so it goes in Thursday, hopefully this will fix it.
One thing is strange though, even with the disconnect message and the controller blinking red, everything still works :***:
Mike
Stroker
Cora
John,
I'm gonna guess that you are getting a ground through the ball that is keeping the lights and blinkers functioning, its just that the puter cant see the "real" ground so its giving you the disconnect message.
jharvey
Shutter Bug
Georgia
John,
I wish that was it, but I have a good ground thru the 7 pin connector, have metered out every connection and have narrowed it down to the brakes, they haven't been serviced in I don't know how long, probably got a magnet issue.
jharvey
Shutter Bug
Georgia
Well, it turned out to be missing insulation on one of the magnet wires grounding out.
Problem solved :thumbsup:
That alarm is annoying -cuss
WD40
Benton AR
Problem solved
Glad you were able to get them fixed. They can sure be a pain when they don't work right. Always good to see where it says. Problem solved;Sweet
;Sweet
jharvey
Shutter Bug
Georgia
Oh it's sooo nice not to hear the annoying chime, pulled all day yesterday and no problems.
I gotta say that the tow/haul mode is absolutely wonderful and love the downshift and turbo whistle when stopping turns some heads :D
powerboatr
yes the tbc is wonderful
it really works its buttt off in traffic but so smooth
cant imagine not having it now
good to hear you found the culprit
swanee
Fillmore, CA
The alarm may be annoying, but would you even have known you had a problem if it hadn't been there? Nice to have found it before it caused an accident or something.
jharvey
Shutter Bug
Georgia
Probably not, but the funny thing was, everything, brakes, lights, signals, still worked even when the TBC was in "fault" mode go figure??
I'm just glad it's fixed :thumbsup:
Nanohawk
