Torque Converter Shifting in/out of lockup
BigDogIDI
John Day, OR
I recently had the transmission (e4od) rebuilt on my 1992. I had an upgraded torque converter installed too. My TC has been shifting in/out of lockup randomly. It will lock and unlock (every 2-3 seconds) for a couple minutes, then I won't have an issue for 10 minutes or so. I cleaned up where the tach sensor connects to the wiring harness and also where the harness plugs into the TPS. (Both checked out with a multimeter test...) This didn't seem to make a difference. Any ideas?
Ddizzy77
West
Might want to disconnect the batteries for an hour or so. See if it keeps doing it.
retiredinhomer
Alaska
what was the idle voltage on the tps? I have mine set for 1.12vdc it changed the whole shifting pattern .
Double-S-Diesel
parts seller
derry pa
check all you lights including parking lightts and 3rd brake lite
had a 96 that the liscensce lite was out and that caused an isssue
also had a 02 van with the 3rd brake lite out do that
other thing to look at is trailer brake control id installed, had one in a 97 that was causing an issue
Sidewinded_idi
Yucaipa ca
Replace your tps. Mine was doing that when it had an internal short. It would test fine through setting with a multimeter but the vibrations going down the road it would lose connectivity and make it think you let off the gas and unlock the converter
