Dsl_Dog_Treat
This might belong here or it might go downstairs, but here's my question(s).
What is the limit of Bio that our engines can run with temps on the cooler sides here in Michigan being used in at the cooler/cold climate seasons without fuel system modifications?
I know that from past readings they eat anything but given the sporadic weather here it makes for a more indepth look.
Reason being is that I stumbled onto a bulk Bio dealer here in Cassopolis that is selling B-25 at $2.63/gal for road use.
Now doing the math with traditional D2 going for $2.99/gal is a no brainer.
The minimum order is 150 gallons so a bulk tank will be needed, one located with hand pump for $100.00.
Plus correct me if I am wrong but no additives are required for using Bio at that percentage?
SO.... If correct, when ULSD comes out, using a B-25 mix would keep me away from adding additives at every fill saving yet another $0.11/gal on fillup.
I really don't have enough mom/pop greasy spoons around this area to be beneficial on home brew so that option would be out.
For those running bio, what are you guys doing to aid in better flow rates for greater mixes and or weather temp cut of rates?
Would this be a mix to run year round without chances of plugging the fuel system?
Sorry, long winded but this is still new to me and may be worthy of a good discussion.
If not swonk away!
Thanks
If not swonk away!
Thanks
