FORDF250HDXLT
im lost on the numbers guys.nothing seems to add up for me at all. using the lumy method for the 7.3l is supposed to be possible.i wounder how many actually have,and what they set the meter too?
my pump is now set to -7 ADTC @ 1400rpm.and this is advancing the pump (turning my mark from lined up,and matching closely to the pic of which Mel refers to above.)
my cetain value i know is approx 40-42.
my engine has more rattle than when i started with matching marks and about -8.5 ATDC.
the more advanced i go (more rattle,and making the line on the ip go toward the pass side) the meter reads closer to BTDC.
if i where to try 1-2 degree's like iv read,the line would be WAY over to the pass side,and it would likely do whos what.i don't dare to advance it that much.know way the mark want to be way over so far,nor sound so god awful.i took it to -3ATDC and went for a ride-sounded REALLY bad.
what is -6ATDC in relation to pulse timing?
i have the meter set to 20 degree offset.the lower 300? or what - 1400rpm setting.
i have read where some claimed they needed to try setting 1400-6000 rpm,and use 2000rpm,yes even with lumy method,but my meter(s) just peg when i do that.
i have 3 lumy probes and two meters.tried 'em all.
using the first cylinder on on the pass side of the engine,and have tried using #4 as well,with same readings.
perhaps i just don't understand what - values mean on the meter,and what 2 ATDC equates too?
can't be using the BTDC side of the meter,cus my mark would be on the other side of the ip,rather than advanced,and i be retarded from lined up and with less rattle.so i didn't even bother trying that of course.
im lost.
for the pic i mention,see here;
http://www.oilburners.net/forums/showthread.php?p=485454#post485454
im lost.
