Matrix37495
The Amish Wolfman
I put my new injectors and newer IP on last night (Thanks again to both Davids) but had a couple questions about timing it...
First, if i unplug the cold timing advance wire can i time it cold?
Second, i know the range for pulse method is 8-9.5° BTDC, but what is the perfect setting for power and lower EGTs? Since i run WMO 90% of the time should i lean more towards the advanced side? 9.5-10°?
