Been trying to hookup an aftermarket tachometer to my 6.9 E350 with C6. Don’t necessary need one, but thought it would be nice.
Anyways, after my first used sensor was no good, I received a new one (Standard Motor) and wired it to my 3” diesel tachometer from eBay. But after some frustrating attempts, the tachometer will not respond to my signal.
I have good resistance about 2500ohms. And an AC voltage of about 0.15V This voltage will increase very precisely as I increase RPM’s.
So my thoughts are the sensor is good. OR I’m not getting enough voltage at idle. Another thread had the sensor volts at about 0.25V. However I would think the tachometer would at least fluctuate at higher RPM’s when the voltages increase above idle… yet nothing.
The Tachometer does react to 12v. The needles drops to 0 from about 400 when it has no power.
I bought this tachometer from eBay last year and payed probably too much for it… can’t return. What are my options for a 3” tachometer?
Thanks!
Thanks!
