tachometer repair/replacement help needed
GREASE FIRE
Falmouth KY
so it looks like i am going to buy the truck after all. The tachometer does not work and i would like it to - supposedly when the engine gets hot it works intermittently but that doesn't cut it for me.
for a 89 f250, where should i start in troubleshooting it? i don't even know where on the engine or trans the tach cable connects, plus i don't know if it is the gauge on the dash that is broke or something else.
any suggestions as to where to start and where a good place to get the parts would be?
thanks,
paul
6 Nebraska IDIs
more than likely its the sender. It'll be in the IP gear housing, on the drivers side. Looks like a bolt with wires coming out of it.
They are common to fail and are like $60 from Ford.
creighta
Sardinia, OH
sender. I replaced one this year for $58.95
Big bolt on top of the IP. When you put the new one in I found that it helped to twist the wires first so that they untwisted as I screwed it in (youll understand when you get started on it)
6 Nebraska IDIs
unfortunately yes the stealership is the only place for it.
Im sure someone will pipe in as to the part number.
suv7734
BC Canada
Part number should be
E5TZ-17B384-A
Check the connections around the base. Sometimes they get a bit worn and frayed and 'connect' to one another. There is a test for it but I don't have it available right now.
