Tach for my automatic
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
Easily. It SHOULD even be wired for one. Just gotta get a tach head and a sending unit. Sending unit is part E5TZ-17B384-A
I purchased mine from: http://www.trademotion.com/parts/in...TZ-17B384-A&action=oePartSearch&siteid=214072
Tach head is a different story, you're gonna have to trawl the yards for one, or find one from another member. I do not know the part number, but they're easy to ID. There are two tachs, a 6000RPM (gasser) and a 4500RPM (ours), just read the numbers. Ours also have a warning red and orange (white on some) bar starting around 3500RPM.
They are rare to find in yards, at least the one near me, and I have lots of our trucks come through. Just pull the cluster, take off the four connection nuts, and it will pop right out. Oh and take the lens off of the instrument cluster. I recondition speedos from our trucks as a hobby, it's really easy if you just look at what you're taking off of the cluster. Anyhow. I BELIEVE the harness is in all of our trucks. Look for a four-wire connectour over on the passenger's fender. Two wires will go to the alternator harness (these are the wires for the ammeter), and the other two, I believe one is green with a yellow hash, should go to another connector, which in your case would be disconnected. Said connectour should be near the injectour pump gear cover. The sensour will just plug right in. There MAY OR MAY NOT be a big port in your gear cover, it will be pointed up about 45 degrees on the driver's side of the cover, the tach sensour will screw right into this port. If you don't have one, get one from a yard truck, they're easy to find, and I'm sure somebody on here has one you can purchase for a song.
That's about it, see this site for some pics of the sensour and where it goes: http://www.dieselhub.com/maintenance/idi-tach-sensor.html
Welcome to Oilburners!
jaluhn83
Upper Marlboro, MD
85 should have the housing for the sensor and the wiring. To the best of my knowledge it's only 83 & early 84 that didn't.
You'll also want the 'circuit card' (wiring film thing) off the back of the cluster since the non tach units don't have the leads for the tach. The wiring to the cluster is there, but the cluster wiring isn't. You can pretty easily get around this by just running wiries, but you have to figure out which terminals and be comfortable doing the wiring.
You can also run an Isspro programmable tach off the stock sensor, and likely other companies have similar tachs that will work.
theguruat12
Certified Tinkerer
This is true, I forgot about that. Luckily that is easy to pull as well, just gotta undo all of the gauge connectour nuts and the voltage pulsatour and it will pull right off. Total of 12 connectour nuts and 1 screw. And take the little lamp housings out, they just twist and pop out the back. The cluster you get the tach from will have this on the back.
jaluhn83
Upper Marlboro, MD
Yep, learned the hard way.
Come to think of it, I think I have a spare tach circuit card wandering around if you really need one.
tke395
