Surging prob.
conan
chetwynd bc
Sorry in advance if this is an obvious one, but I don't have time to do a search. I have a 92 7.3 IDI. The problem is, it surges any time I maintain a constant speed. It is very smooth on accel. and decel., but as soon as the speed/rpm level out, it starts to surge steadily. Not sur where to start.
I appreciate any advise.
Thanks,
Conan
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Need more info. How old is the fuel filter? Next I'd look at the fuel pump, then the IP/injectors. Or, it could be tranny related, maybe the torque converter locking and unlocking or just slipping?
conan
chetwynd bc
Sorry, manual tranny so shouldn't be related. Fuel filter replaced about 6000 k ago. Aux. pump recently repaced. Haven't done the injector pump or return line kit. Has about 350,000 km on it, but like I said, runs smooth and pulls good, so I think it's getting enough fuel.
deadeyeb
MA.
Is the truck smoking when it is surging ,sounds close to the problem I'm having. I have a automatic though. when the rpm's level out my truck stutters and will smoke , but hit the gas and clears right up. when you find a solution I would be very interested on what it took to fix it. thanks for your time.
typ4
Newberg,OR
I would check for a suction leak, sounds like air is getting in the pump, take my word on this one, I have diesel flavored pits to prove it. Bad prefilter, had a pinhole.
Papabear
Papabear
Grande Prairie, AB
is it turboed? if so i would check the vacuum actuator on the wastegate and/or vac pump. the wastegate could be opening prematurely/intermittantly therefore dumping the boost. Or you may have a fuel system leak that is leaking at that weird point where it is letting air in but no fuel out (as weird as it sounds) i have heard of the tire valve like bleeder getting sucked in because the low pressure pump is not keeping up and the high pressure pump is cavitating the system creating vacuum at the valve therefore sucking the valve pin in. Or the pickup screen in your tank may be plugged causing the same issue. Just a few thoughts from thinking outside the box.
conan
chetwynd bc
It doesn't have a turbo. I will check for an air leak on the suction. Would excessive slop in the timing chain cause it? Maybe when the rpm's settle out the fuel pump is inconsistent? Just a thought...
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
We have a timing chain? Maybe check the fuel lines from the pump back to the tank for possible air leak. And it may not leak fuel, but allow air in when the pump is working.
Fozz
Camarillo, CA
I have a light surging at speed too. Mine is most pronounced with the cruise on, and engine turning 15-1600 rpm. I just found out my injectors are popping too early and puddling, so I'm hoping new injectors will cure it. I won't get around to replacing for a few weeks yet, but I'll post results if it fixes it.
There is no timing chain in these engines. Your surging is a timing variance caused by one of these possible things...
1) - Bad I.P. (advance piston/bore worn)
2) - Air in fuel
3) - Problem with fuel presure fluctuating.
You don't see the problem on acceleration because your supplying more fuel than the engine can burn, but it is doing it then as well. You just don't feel it.
